Date/Time: Sun, 19 May 2024 12:01:51 +0000
FXCM Order Placement Issue
View Count: 483
[2020-08-25 13:52:47] |
User561221 - Posts: 11 |
Yesterday and today I've been seeing 10pt+ gaps difference between what's on the screen and the entry/exit point of the trade that is being recorded. It was all fine last week. I've added a screenshot so you can see the issue. In both trades the entry/exit points are not covered by the candles.
NAS Trade FXCM 25th Aug.png / V - Attached On 2020-08-25 13:51:16 UTC - Size: 23.54 KB - 175 views |
[2020-08-25 19:37:49] |
The issue has now been resolved. To redownload the affected data, refer to the information here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-26 00:31:11] |
Full information: RESOLVED: Ask Price not Updating on Bid/Ask Updates for some Services/Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
