Date/Time: Sat, 18 May 2024 21:37:51 +0000
huge pip difference eurusd between greenchart and coinexx
View Count: 467
[2020-08-25 12:32:11] |
User225558 - Posts: 1 |
there is a 80 to 100 point difference between greenchart and coinexx. im in version 2120 that has worked fine for many others in my group
[2020-08-25 22:17:58] |
This issue was resolved earlier today and was affecting older versions of Sierra Chart being fed from some servers. The basic problem was the ask price was not updating. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-25 22:18:09
[2020-08-25 23:31:19] |
Regarding the issue, refer to: RESOLVED: Ask Price not Updating on Bid/Ask Updates for some Services/Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
