Date/Time: Sun, 19 May 2024 02:02:12 +0000
Bid Ask Depth Bars Not Showing
View Count: 658
[2020-08-25 02:26:30] |
User347150 - Posts: 29 |
Hello, The Bid Ask Depth Bars study appears to have random breaks in the study, where the study does not display, then reappears, and alternate in appearing and disappearing as I scroll back on the chart. Please help me so that the study will continuously display for each price bar that is displayed, as I scroll back on the chart, or when I use the replay chart feature. Thank you in advance for all of your help. Sincerely, Everett |
[2020-08-25 04:18:42] |
We see you are using CQG. It may be related to the CQG data feed. We recommend using the Denali Exchange Data Feed: Denali Exchange Data Feed In general though the solution to this would be to set this setting to a nonzero number and a smaller number: Chart Settings: Number of Levels for Bid/Ask Depth Calculations (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-25 04:19:50
