Date/Time: Sun, 19 May 2024 07:24:09 +0000
Global Cursor missing
View Count: 723
[2020-08-24 02:45:52] |
User39772 - Posts: 311 |
Hello, since my update to 2158 the global curser does not appear after it is enabled.
[2020-08-25 00:30:07] |
Are you still seeing an issue and need help? This tool does work properly in version 2158.
[2020-08-25 08:05:41] |
Yes. Tools -> Global Cursor is checked but no global cursor visible. |
[2020-08-26 00:40:42] |
Are you able to see the Chart Values tool on the chart you are using it on? Documentation: Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-26 07:10:14] |
Yes the Windows -> Chart Values Tool works e.g. in connection with Tools -> Line.
[2020-08-26 10:08:10] |
This is not what we meant. Are you able to use the Chart Values tool on the specific chart you are using it with? And also check all of the settings for that tool including the colors: Chart Drawing Tools: Chart Values Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-26 10:08:24
