Date/Time: Sun, 19 May 2024 06:58:56 +0000
add commissions to the profit and loss calculation
View Count: 2146
[2020-08-20 17:54:55] |
User962067 - Posts: 11 |
In the graph showing NPL, is there a way to add to that calculation the instrument fees? How could I add the commission value to the trading history?
[2020-08-20 20:04:42] |
Refer to the information here: Trade Activity Log: Use Commission And here: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-24 19:00:19] |
Good day, how do I include the commissions in the NPL calculation in the chart? thanks for the documentation I already added the commissions to the trading history, but I didn't see anything about adding the commission to the NPL in the chart
[2020-08-24 22:12:13] |
Refer to this particular setting: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-25 16:58:10] |
Good day, the configuration specifies that you suggest I already have it active, it follows the same, it does not add the commission value to the NPL of the chart, I imagine that for Global Profit/Loss Management it is based on this same true value or I am wrong? because I would like it to give the exact NPL including the commission.
Date Time Of Last Edit: 2020-08-25 17:00:41
2020-08-25_18-51-54.png / V - Attached On 2020-08-25 16:57:42 UTC - Size: 47.09 KB - 317 views 2020-08-25_18-55-59.png / V - Attached On 2020-08-25 16:57:55 UTC - Size: 53.23 KB - 241 views |
[2020-08-26 00:36:07] |
That setting does do what you expect but it only affects the Closed Trades. Not the open trade. Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
