Date/Time: Tue, 10 Nov 2026 06:30:46 +0000
steps for denali feed, broker executions at same time and making sure connections correct
View Count: 928
[2020-08-08 17:36:20]
HeyUgly - Posts: 288
im a little confused,
I have a Denali feed dioe futures, and sierra feed for Stocks, working great
i now have a cannon account, which CQG is handling executions, i have the CQG login, and have connected it in sierra
question
1. how do i make sure Denali/Sierra is the data feed, and how do i know im connected to CQG at the same time for executions? and also, how do i know im in Demo mode for CQG when logged into sierra to test everything before trading off it all live here?
2. do i need to connect the cannon account for anything? seeing that CQG is handling everything i dont think i do??
thanks in advance!!
[2020-08-10 20:53:52]
1a. Make sure it is the Denali Data Feed: Refer to the information here, particularly towards the end of the section discussing the [M] symbol.
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
1b. Connected to CQG: As long as you have entered the information properly in Data/Trade Service Settings, then you are connected. You can look in your Message Log to see if there are any issues. Refer to the information here:
Message Log
1c. Sierra Chart offers Simulation Mode. Refer to the information here:
Trade Simulation
2. No, you do not need to do anything with regards to Cannon Trading, it is the CQG connection that is important.
