Date/Time: Sat, 11 May 2024 13:38:18 +0000
v2141 Transact Daily Session Values - Daily Open Price
View Count: 468
[2020-07-28 22:40:19] |
User90125 - Posts: 715 |
Using 64-bit v2141 (build 32436), with the Service Setting >> Enable Market Depth Data and Daily Session Values set to True in the Data/Trade Service Settings for Transact, as shown here: The daily OPEN price is reverting to its previous behavior when displayed in the QuoteBoard. Quoteboard fields that don't require a correct OPEN price do populate correctly when the system is reset or started up during the day. However, this means that the OPEN, Change from OPEN, and Change from OPEN % fields are potentially wrong when using the Transact feed. Could you check with Transact to make sure the proper Daily Session Values including the correct daily OPEN price are captured and always sent in the revised price feed? Thanks. Date Time Of Last Edit: 2020-07-28 22:40:58
[2020-07-29 01:19:14] |
We do not see that they provide the Daily Open price.
[2020-07-29 02:17:05] |
For the sake of data feed integrity, could you have Transact add it?
