Date/Time: Sun, 12 May 2024 06:33:10 +0000
Prices are updatingvery slowly vs what i see on IBKR
View Count: 526
[2020-07-28 09:36:32] |
Andre - Posts: 31 |
Hi, I am Using IBKR and Denali feed and the prices on SC update only ever other second. I read through the support board and did not find a solution. I tried to disconnect IBKR and only run SC-Data but that did not look much better. The range charts and TPO's do not move/update at the same time either. Update on this. I tried to have a ES TPO chart and 20 tick range chart only and they also do not move in-sync. Update 2: I added a DOM to check against the range and TPO chart and all three are out of sync. Do you have any quick fixes i can try? Thank you very much in advance. Date Time Of Last Edit: 2020-07-28 15:26:48
[2020-07-28 18:48:44] |
Are you still having an issue? Refer to help topic 4: Prices / Data Falling Behind Each chart will update independently. But for the same symbol and at any moment they should be showing the same price unless you are using a high Chart Update Interval: https://www.sierrachart.com/index.php?page=doc/helpdetails4.html#h4.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-28 18:49:20
