Date/Time: Fri, 10 May 2024 11:00:18 +0000
Charts not changing
View Count: 430
[2020-07-27 22:14:56] |
User474604 - Posts: 1 |
Hello, I have just joined for 6 months. I am having trouble changing my charts. I click on the chart I want to change, put in AUDUSD for example and press enter but nothing happens. Can you help. Regards. Brett. |
[2020-07-28 19:13:15] |
We are not sure exactly what you are asking about, so here are the most likely answers. First, refer to the information here for how to change the symbol of a chart: Changing the Symbol of a Chart Second, if you are stating that the ability to switch symbols through the keyboard is not working, then ensure that this setting is enabled: General Settings Window: Support Symbol Entry from Chart Window (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
