Date/Time: Mon, 20 May 2024 01:27:10 +0000
Daily OHLC
View Count: 544
[2020-07-27 15:30:12] |
User837393 - Posts: 132 |
Hello, Is there a way to extend the ploted line of the Daily OHLC. The lines seems to only extend as the time goes. I'd like to extend them at the session close. See image. Best regards http://www.sierrachart.com/image.php?Image=1595863735527.png |
[2020-07-27 19:42:34] |
We are not sure exactly what you are looking for, but if you want to extend the OHLC lines into the fill space to the right, then you change the Draw Style for the lines to Line Extend to Edge. Just keep in mind that if you are looking at multiple days, this will cause the line to be drawn continuously from the previous day into the new day, which can create an odd drawing. Refer to the information here: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
