Date/Time: Sun, 12 May 2024 12:29:32 +0000
Numbers Bars minimum highlight not showing
View Count: 472
[2020-07-25 19:11:54] |
User98657 - Posts: 304 |
I'm setting up numbers bars. Fairly straight forward, nothing special. In:16 = Bid Vol x Ask Vol In:17 = Ask/Bid Volume Split Profile (color for all is gray) In:18 = Based on Volume Percentage Column 2, Column 3, Pullback Col., 1, 2, 3 all = No Text In: 65 = Column 1 In: 66 = Red In: 68 = Column 1 In: 69 = Blue In: 99 = Automatic For some reason I see the Blue highlight on every bar, but I'm only seeing the red highlight on very few bars throughout the chart. Based on In:16 I'm not sure why I'm not seeing a red highlight on virtually every bar. Appreciate your thoughts. Date Time Of Last Edit: 2020-07-25 20:12:14
[2020-07-29 19:28:46] |
John - SC Support - Posts: 31555 |
You need to set the option for Ignore 0 Values for Minimum Highlight to Yes. Refer to the following documentation: Numbers Bars: Ignore 0 Values for Minimum Highlight For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
