Date/Time: Tue, 10 Nov 2026 06:59:05 +0000
what are the symbols for continuous contracts of emini futures.
View Count: 2719
| [2020-07-24 04:54:29] |
| Kadi - Posts: 1 |
1.Please let me know the continuous contract symbols for emini futures contracts ES, NQ, RTY YM. 2. How to set to show the bar values (OP, Hi, Lo, Clo)when I move the curser to any particular bar. currently, I can only see the values of the last bar which shows up in the chart values window. Thanks. |
| [2020-07-24 20:18:33] |
1. Refer to the following information: Continuous Futures Contract Charts 2. You need to use the Tool Values Window or the Compact Tool Values Window. Refer to the information here: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
