Date/Time: Thu, 16 May 2024 04:44:42 +0000
Limit Pulling and Stacking Depth Levels
View Count: 729
[2020-07-15 02:05:12] |
NG1980 - Posts: 39 |
is there a way to limit the number of depth levels for Pulling and Stacking data? I'm using it with Numbers Calculated Values 2. I tried to limit the depth levels in the Data/Trade Service settings as well as in Chart Settings > Advanced 3 tab. However, the pulling and stacking data seems to use all available levels no matter what.
[2020-07-15 05:00:51] |
Sierra_Chart Engineering - Posts: 14362 |
You need use this setting: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
