Date/Time: Thu, 16 May 2024 09:36:18 +0000
DOM only
View Count: 517
[2020-07-14 16:24:14] |
User800328 - Posts: 50 |
Hello, I only need DOM for my Sierra Usage w/o any use of charts. How much do I have to pay. I have been paying for the following for a long time(almost 3 years) . Sierra Usage ($35) . Seirra Feed/Denali Feed ($25) . Exchange Feed ($10.4) So, my question, I am moving exclusively to DOM and don't use charts any more. It's getting expensive to use Sierra per month, so I need to reduce the cost and just use the DOM, without any need to charts. How can I do that ? Thanks. |
[2020-07-15 05:17:34] |
Actually, you are only paying $26 per month for the Sierra Usage Time, as you are on Service Package 3. Therefore, the only way to cut down the cost would be to pay for multiple months up front for your Sierra Chart usage. Refer to the information here: Description of Service Packages and Pricing: Multiple Month Purchase Discount The other way to cut your costs is to switch to the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service You should save on trading commissions and you will save five dollars a month on the Denali exchange data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-15 05:19:13
