Date/Time: Fri, 13 Nov 2026 21:50:22 +0000
Trading using CME/CBOT
View Count: 2239
| [2013-04-17 01:15:38] |
| tr726 - Posts: 30 |
Is there a difference between trading an instrument using CME/CBOT? Ex: ZN cme gateway or ZN cbot gateway.
| [2013-04-17 01:58:31] |
This only applies to when using a Trading Technologies FIX Adapter and only your broker would know which gateway is available.
| [2022-11-12 02:31:04] |
| User624168 - Posts: 4 |
how to change from cbot to cme service package
| [2022-11-12 13:01:28] |
| Sierra_Chart Engineering - Posts: 25422 |
The first thing you must do is update Sierra Chart to the current version. Instructions: Software Download: Fast Update Did you need real-time data or just delayed data? You are already set to get delayed data: Delayed Exchange Data Feed If you require real-time data you can activate the exchanges that you need. Follow the instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-12 13:01:53
