Date/Time: Tue, 10 Nov 2026 07:21:15 +0000
Live support
View Count: 936
| [2020-07-13 17:10:41] |
| Evil Options - Posts: 4 |
I'm having a major issue with my bracket orders and I need this resolved or I will have to switch to another charting software. - The target Limit order is automatically cancelling out my stop Limit order when the market hits it in (LIVE) mode and NOT in Sim mode. Please send a link that I can prepay to have remote assistance performed. Best |
| [2020-07-13 19:57:58] |
We can go over this with you, this evening.
| [2020-07-13 22:39:15] |
How do we coordinate?
| [2020-07-13 22:41:18] |
How do we coordinate...I'm available now.
| [2020-07-14 01:11:59] |
We can call in about 20 minutes.
| [2020-07-14 01:36:19] |
| user2837 - Posts: 76 |
Once this matter is resolved, can you please post a summary. I am preparing to live trade with Sierra and AMP, and this is the type of issue I want to be informed about. Thanks.
| [2020-07-14 02:25:35] |
In regards to the first issue, we called the user, no cost, and what we determined is that when using CQG server controlled OCO orders, once one side of that order set fills the other side completely cancels even if the order quantities are different. So in the case where the Target order has a quantity of 1 and the stop order has a quantity of 2, when the target order fills the stop order fully cancels. Now recently we forced on the CQG server-side OC orders for safety reasons but we can see that they do not even function as expected. The solution is to use the Sierra Chart Order Routing Service where there will be management of OCO and bracket orders fully on the server and as expected. To begin the process complete this form here: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm The cost is only 20 USD a month more for the Denali data feed and this gives you also extended market depth. ---- I currently use NT8, and was wondering if you have the feed for YM dow? Also how does the feed work with your subscription? Do you supply it or do I need to pay externally and link it to sierra? So if I purchase your 36 usd per month subscription, does a feed come with it? Denali Exchange Data Feed However authorizing the CME data adds complexity. Since you are with ninja trader, refer to this page: Using Sierra Chart with Ninja Trader Brokerage ---- Once this matter is resolved, can you please post a summary. I am preparing to live trade with Sierra and AMP, and this is the type of issue I want to be informed about. Thanks. You are not affected by this because you are already on the Sierra Chart order routing service. Which is going to even become better towards the end of the year with our own direct CME order routing bypassing TT altogether.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-14 02:27:02
