Date/Time: Thu, 16 May 2024 15:08:51 +0000
How to disable VAH/VAL line connection between multiple volume profiles on chart?
View Count: 562
[2020-07-13 15:40:59] |
MatZer0 - Posts: 36 |
Hi Sorry to bother you, but I couldn't figure it out on my own Please take a look at attached screenshot I have multiple volume profiles set to draw each 25K of contracts. I display only VAH, VAL and VPOC from them I don't want the VAH/VAL/VPOC lines from separate profiles to be connected, it makes my chart a bit messy. How can I turn off this function and display this lines completely separately? |
vp_vah_val_do_not_connect.png / V - Attached On 2020-07-13 15:38:08 UTC - Size: 140.13 KB - 230 views |
[2020-07-13 17:38:28] |
Additionally I'm looking for function that I used in Investor R/T, it's called "Auto Merge Profiles With Overlapping Value Areas". Do you have something similar in SC?
[2020-07-13 19:57:15] |
Go to the Subgraphs for the study and change the Draw Style from Line to Dash. Refer to the information here for the Draw Style: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-14 10:55:29] |
Can you please also comment on the "Auto Merge Profiles With Overlapping Value Areas" feature? Do we have similar one in Sierra?
[2020-07-15 05:15:55] |
We are not familiar with "Auto Merge Profiles with Overlapping Value Areas". So it is not available. In the case of TPO Profile charts you are able to merge TPO profiles together. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Splitting and Merging TPO Profiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-15 05:16:38
