Date/Time: Fri, 03 May 2024 14:24:25 +0000
Automatic Drawing of The High and Low of a 30 Minute Candlestick on a 5 Minute Chart?
View Count: 1211
[2020-07-11 05:32:16] |
User344276 - Posts: 65 |
How do I automatically get the lines of the high and low areas on a 30 minute candlestick to occur on a 5 minute chart without having to manually draw them? Is there an indicator that can do this every 30 minutes that passes? Thank you.
[2020-07-12 14:22:00] |
Refer to this study: Study/Price Overlay Study And specifically to this Input for that study: Study/Price Overlay Study: Use Multicolumn Rectangle Style for Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-13 08:43:03] |
I prefer not to use the multi-column rectangular style box because it makes it difficult to see the price bars and it gets in the way of the indicators that are on the main price graph. Is there a way to automatically get two horizontal lines that display the high and low of the 30 minute bar? Thank you.
Date Time Of Last Edit: 2020-07-13 08:44:35
[2020-07-13 14:30:49] |
Sawtooth - Posts: 3992 |
It can be done with 3 instances of the Spreadsheet Formula study, or with one instance of the Spreadsheet Study study.
Date Time Of Last Edit: 2020-07-13 15:16:09
[2020-07-13 15:48:26] |
mkata - Posts: 103 |
I would use the Period OHLC-Variable Period study. Set to 30M. Simple and easy.
[2020-07-13 20:42:49] |
In regards to post #3, we will add that capability.
