Date/Time: Mon, 29 Apr 2024 11:44:25 +0000
[Locked] - Historic data charts
View Count: 582
[2020-07-10 11:33:10] |
TIM - Posts: 16 |
Hello, I am using Dorman as a gateway to exchanges through Rithmic. Everything is working fine for exchange data, but the download of historical data from your servers is not working properly and backfilling daily and monthly charts. I get holes in historic data from recent data. It started last month but as an engineer I try to keep a low profile on questions to you guys. But it has been a month and it simply won t work. Does the program solution you guys supplied us Sierra customers to put in the Rim folder work fine with your historical data servers? Thanks in advance, My best regards. |
[2020-07-10 20:12:52] |
download of historical data from your servers is not working properly and backfilling daily and monthly charts. I get holes in historic data from recent data. In your case the data is coming from Rithmic. Not Sierra Chart. So the limitation is with Rithmic and now you can see the reality of what Rithmic offers in regards to historical data.You need to change to the Advanced service package for historical data when using Rithmic: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. This will give you the Sierra Chart Historical Data Service integrated with Rithmic. We recommend that you change to the Sierra Chart Order Routing service for the best solution: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-10 20:15:25
