Date/Time: Wed, 01 May 2024 16:32:24 +0000
Running out of memory
View Count: 708
[2020-07-09 07:11:54] |
User432142 - Posts: 44 |
when l load market depth for only 1 seconds chart, even if l have enough memory and disc space l receive the following message from message log NQU20_FUT_CME [CV][M] 1 Sec #3 | Reloading chart. | 2020-07-09 01:56:19.345 Loading market depth data. | 2020-07-09 01:56:20.055 Loaded depth data records for NQU20_FUT_CME 2020-07-05 from 2020-07-05 08:59:56 to 2020-07-05 08:59:56. | 2020-07-09 01:56:20.058 Loaded depth data records for NQU20_FUT_CME 2020-07-06 from 2020-07-05 19:48:59 to 2020-07-06 10:39:57. | 2020-07-09 01:56:20.923 Loaded depth data records for NQU20_FUT_CME 2020-07-07 from 2020-07-06 19:17:15 to 2020-07-07 13:36:01. | 2020-07-09 01:56:22.192 Failed to add to the depth data for NQU20_FUT_CME, possibly as a result of running out of memory. The depth data accounted for 5.59 gigabytes of memory. Depth data will be unavailable until the chart can be reloaded. | 2020-07-09 01:56:24.813 * |
Attachment Deleted. memory.jpg / V - Attached On 2020-07-09 07:07:30 UTC - Size: 65.72 KB - 251 views SIZE OF SSD.jpg / V - Attached On 2020-07-09 07:07:41 UTC - Size: 27.25 KB - 246 views |
[2020-07-09 20:17:02] |
Refer to: Working With Charts: Out of Memory Condition , even if l have enough memory Clearly your operating system is not making the memory available.
[2020-07-10 05:27:15] |
market depth only doesnt work when l use 1 second time based chart. when l use 1 tick or 1 volume or 2 seconds chart it works well NQU20_FUT_CME [CV][M] 1 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-07-10 00:23:25.718 NQU20_FUT_CME [CV][M] 1 Sec #3 | Reloading chart. | 2020-07-10 00:24:21.511 Loading market depth data. | 2020-07-10 00:24:22.923 Loaded depth data records for NQU20_FUT_CME 2020-07-01 from 2020-07-01 08:18:21 to 2020-07-01 10:44:14. | 2020-07-10 00:24:23.399 Loaded depth data records for NQU20_FUT_CME 2020-07-02 from 2020-07-01 22:39:48 to 2020-07-02 10:48:19. | 2020-07-10 00:24:24.246 Loaded depth data records for NQU20_FUT_CME 2020-07-03 from 2020-07-02 23:35:56 to 2020-07-03 12:00:00. | 2020-07-10 00:24:24.576 Loaded depth data records for NQU20_FUT_CME 2020-07-05 from 2020-07-05 08:59:56 to 2020-07-05 08:59:56. | 2020-07-10 00:24:24.577 Loaded depth data records for NQU20_FUT_CME 2020-07-06 from 2020-07-05 19:48:59 to 2020-07-06 10:39:57. | 2020-07-10 00:24:25.361 Loaded depth data records for NQU20_FUT_CME 2020-07-07 from 2020-07-06 19:17:15 to 2020-07-07 13:36:01. | 2020-07-10 00:24:26.622 Failed to add to the depth data for NQU20_FUT_CME, possibly as a result of running out of memory. The depth data accounted for 5.59 gigabytes of memory. Depth data will be unavailable until the chart can be reloaded. | 2020-07-10 00:24:28.648 * NQU20_FUT_CME [CV][M] 1 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-07-10 00:24:28.651 NQU20_FUT_CME [CV][M] 1 Volume #3 | Reloading chart. | 2020-07-10 00:25:03.999 Loading market depth data. | 2020-07-10 00:25:08.830 Loaded depth data records for NQU20_FUT_CME 2020-07-01 from 2020-07-01 08:18:21 to 2020-07-01 10:44:14. | 2020-07-10 00:25:09.265 Loaded depth data records for NQU20_FUT_CME 2020-07-02 from 2020-07-01 22:39:48 to 2020-07-02 10:48:19. | 2020-07-10 00:25:09.950 Loaded depth data records for NQU20_FUT_CME 2020-07-03 from 2020-07-02 23:35:56 to 2020-07-03 12:00:00. | 2020-07-10 00:25:10.174 Loaded depth data records for NQU20_FUT_CME 2020-07-05 from 2020-07-05 08:59:56 to 2020-07-05 08:59:56. | 2020-07-10 00:25:10.178 Loaded depth data records for NQU20_FUT_CME 2020-07-06 from 2020-07-05 19:48:59 to 2020-07-06 10:39:57. | 2020-07-10 00:25:10.803 Loaded depth data records for NQU20_FUT_CME 2020-07-07 from 2020-07-06 19:17:15 to 2020-07-07 13:36:01. | 2020-07-10 00:25:11.821 Loaded depth data records for NQU20_FUT_CME 2020-07-08 from 2020-07-07 19:05:57 to 2020-07-08 13:38:18. | 2020-07-10 00:25:12.901 Loaded depth data records for NQU20_FUT_CME 2020-07-09 from 2020-07-08 19:15:10 to 2020-07-09 12:43:38. | 2020-07-10 00:25:13.871 Loaded depth data records for NQU20_FUT_CME 2020-07-10 from 2020-07-09 22:01:22 to 2020-07-10 00:24:59. | 2020-07-10 00:25:13.910 NQU20_FUT_CME [CV][M] 1 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-07-10 00:25:13.912 |
[2020-07-12 10:36:50] |
the depth data from 8th july has an issue which is attached when loaded together with another depth data
Attachment Deleted. |
