Date/Time: Fri, 03 May 2024 15:04:53 +0000
Message log error message
View Count: 491
[2020-07-09 06:20:06] |
User106180 - Posts: 88 |
I keep getting the following error message in the message log: Error creating process Z:\Users\w\Desktop\Sierra Chart.sh. Windows error code 2: The system cannot find the file specified. | 2020-07-09 16:12:53.279 *
Sierra Chart is installed in C:\SierraChart. This is a new install and I did copy some files from the previous install which may be causing the problem. I also reinstalled Sierra Chart and the error message persisted. Thanks. |
[2020-07-09 08:48:10] |
User672883 - Posts: 4 |
Posting with my active account.
[2020-07-09 11:19:53] |
That message looks like it is the result of a program set to be run through the Alert settings: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#RunProgramOnAlert Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
