Date/Time: Sun, 05 May 2024 15:15:53 +0000
Midline for channel tools
View Count: 730
[2020-07-08 18:53:14] |
User50927 - Posts: 90 |
Can a midline option be added to both the Parallel Rays and Parallel Lines tools? I thought that was there at some point but now it's gone for some reason. Thanks.
[2020-11-22 06:59:21] |
Its been a few months so I was wondering if you could at least add the "Draw Midline" option to just the Parallel Rays tool which I used A LOT, the same way you make it available for "Extending Rectangle" tool. Thanks.
[2020-11-23 15:52:28] |
John - SC Support - Posts: 31364 |
You can add a midline to both the Parallel Lines and Parallel Rays tools. You just need to go to the Drawing Properties (or Configuration window) and add a Level by selecting the + button. Then enter a value of 50 to get the midline (50 in this case is 50% of the distance between the lines). Refer to the information in this section: Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
