Date/Time: Wed, 08 May 2024 01:06:34 +0000
Trading Options
View Count: 456
[2020-07-08 13:27:24] |
User680605 - Posts: 5 |
Can Options be traded via Sierra Chart? I see the Options button in the symbol lookup, but was unable to access a chart. I tried November soybeans for example. |
[2020-07-08 20:05:43] |
For options trading we recommend using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service We cannot help with options trading on CQG. But check with your broker to make sure they support trading options over TT. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
