Date/Time: Sat, 04 May 2024 15:37:51 +0000
Spreadsheet Trading during special incidents
View Count: 491
[2020-07-07 12:14:48] |
User917140 - Posts: 7 |
I have a question regarding the automated spreadsheet trading. What happens when I am buying a position and after that there is a power outage, computer crash, internet break down etc.? Or what happens with my buy entry conditions are met during one of those incidents? Is there a SC server on which the (open) orders are saved? |
[2020-07-08 06:22:22] |
We see you are using Rithmic. We recommend you change to the Sierra Chart order routing service so you have server managed OCO and bracket orders: Sierra Chart / Trading Technologies Futures Order Routing Service And you need to use Attached Orders: Attached Orders Make sure you use both a Target and Stop order. You must specify both to take advantage of server-side bracket orders. Also any new automated trading orders which occur when Sierra Chart is not connected to the trading server, will not get processed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-08 06:23:31
