Date/Time: Tue, 07 May 2024 03:09:08 +0000
Right mouse click on chart does not bring up pop up menu
View Count: 472
[2020-07-06 17:51:33] |
AlexAL - Posts: 4 |
hello,Right mouse click on chart does not bring up pop up menu. i have latest ver. 2130. Thanks in advance. |
[2020-07-06 18:57:14] |
We do not observe any problem with this at all. We recommend restarting Sierra Chart.
[2020-07-06 19:41:40] |
AlexAL - Posts: 4 |
I did restart sierra chart, i rebooted windows, no luck :-(
[2020-07-06 20:06:39] |
Run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Otherwise, we really do not know what the problem is in your case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
