Date/Time: Tue, 30 Apr 2024 00:04:03 +0000
Can't connect to realtime chart FGBL
View Count: 518
[2020-07-03 16:18:03] |
User461803 - Posts: 1 |
[2020-07-03 17:17:08] |
To begin with, you are not connected to any Real-Time data. It looks like you were wanting to get data from the CME Group, but there has not been a selection of the specific exchange desired. You are also setup to have this billed through AMP, so let AMP know to complete the setup for the Denali Exchange Data Feed and let them know which Exchange(s) you want. You will find the list of exchanges here: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) If you want to get Real-Time data for FGBL, then you would need to get the EUREX data feed. To do this, you would need to use the Sierra Chart Exchange Data Feed. You would need to pay for this directly to us (Sierra Chart) as AMP is not setup to perform billing for that data feed. Refer to the information here for the Sierra Chart Exchange Data Feed, including pricing and Setup Instructions: Sierra Chart Exchange Data Feed In order to have both the CME and EUREX data, you would need to have both the Denali and the Sierra Chart Exchange Data Feeds active. You would then get a $12.00 USD credit to your account for each month in which both data feeds are active. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
