Date/Time: Sun, 28 Apr 2024 17:32:33 +0000
Is it possible to show a line over chart using price level pointed with my mouse in DOM?
View Count: 868
[2020-07-03 16:12:47] |
MatZer0 - Posts: 36 |
Hi Is it possible to show a line on chart, that line should be synchronized with price level where currently my mouse is pointing in DOM? Please take a look at attached screenshot from other platform. It shows exactly what I'd like to see. Simple line highlighting a price level that I point in DOM How can I replicate this function in Sierra? |
dom higlight.png / V - Attached On 2020-07-03 16:08:26 UTC - Size: 184.34 KB - 238 views Attachment Deleted. |
[2020-07-06 23:03:42] |
You can do this with the Chart Values tool crosshair. Refer to the information here: Chart Drawing Tools: Chart Values/Crosshair Also refer to: Chart Trading and the Chart DOM: Having Horizontal Line Across Chart at Highlighted Level on Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
