Date/Time: Wed, 01 May 2024 22:54:21 +0000
L2 / Market Depth on right side of chart
View Count: 1274
[2020-07-02 23:12:44] |
User255336 - Posts: 28 |
Hello, 1) Is there a way to put level 2 / market depth on the right side of the chart window, and / or market depth historical data? I'd like to see number of bids/asks on the side of the chart. See group-l2.png attached 2) Is there a way to display time information, such as number of buy trades, sell trades, and delta? See time-information.png attached 2) Is there a way to group charts in tabs, so I can have different time frames that I can access via tabs, or do I need to just manually change time frames? See group-l2.png attached Below is an example from another platform showing market depth on the right side of the chart: |
Attachment Deleted. time-information.png / V - Attached On 2020-07-02 22:59:53 UTC - Size: 28.19 KB - 275 views group-l2.png / V - Attached On 2020-07-02 23:12:29 UTC - Size: 430.08 KB - 318 views |
[2020-07-02 23:14:42] |
Here is an example of what I was looking to do in Sierra Charts - see the market depth historical data with market depth data to the right See attached. Thank you! |
dom-surface.png / V - Attached On 2020-07-02 23:14:37 UTC - Size: 1022.04 KB - 323 views |
[2020-07-07 11:16:37] |
Refer to the information for the Market Depth Historical Graph here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph And refer to the information on customizing the Chart DOM columns, which will allow you add various columns along with the volume bars, here: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) And finally, if you are looking for Large Trade Markers, then refer to the information for the Large Volume Trade Indicator here: Large Volume Trade Indicator 2. Have a look at the available studies here: Technical Studies Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-07 11:25:19
