Date/Time: Tue, 07 May 2024 12:11:36 +0000
Chart Window numerical size/dimensions/pixels input
View Count: 637
[2020-07-02 22:33:15] |
whats1thingnow - Posts: 407 |
Hi, I was wondering if this is already a feature. I run multiple charts and i want the charts to be the EXACT same size (height and width) so i can line up all 5 of them vertically. Instead of dragging the detached chart window to adjust the height and width, is it possible to type in and specify the window size? For example, I start a new chart. I go to settings and type in 400x600. THank you! |
[2020-07-03 09:20:19] |
No but have a look at these settings: General Settings Window: Use Windows Custom Grid Layout (Global Settings >> General Settings >> Windows >> Window Tiling) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
