Date/Time: Sun, 05 May 2024 00:01:14 +0000
Daily P/L Errors
View Count: 492
[2020-07-01 15:30:16] |
Stage 5 Trading - Posts: 152 |
A Stage 5 client is experiencing issues with his Daily P/L value showing an incorrect value. The client's fill log from Sierra matches his fill log from his Gain brokerage account, so the problem is not coming from missing fills. I went through this link: Help With Daily Profit/Loss Value and it seemed like the issues described there are generally caused by those missing fills. Do you know where else the problem could be coming from?
[2020-07-01 18:41:55] |
If there are no missing order fills, then adjust the Order Fills Start Date-Time Chart Setting to just before the start of the Positions for the day: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-01 18:43:20
