Date/Time: Sun, 05 May 2024 10:51:37 +0000
Bar timer
View Count: 917
[2020-06-30 12:17:42] |
Therese Kamm - Posts: 4 |
How do I set a bar timer on the chart?
[2020-06-30 19:11:03] |
We assume you are referring to the following study: Countdown Timer Refer to the information here for how to add a study to a chart: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
