Date/Time: Fri, 03 May 2024 16:55:46 +0000
Support/res lines, manually place/move quickly
View Count: 554
[2020-06-30 04:32:32] |
Willson - Posts: 176 |
Want to use mouse to position support/resistance lines on a chart manually. Want to avoid creating lines one at a time. Want to grab a line and position it or delete it and then repeat as often as desired. Also nice to have several (pre-set) line colors without going thru a lengthy color adjustment. Want to avoid time to create lies one at a time. Cant post this to usual "user help" messages
[2020-07-01 07:20:31] |
This is all fully supported. Refer to: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step (Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-01 07:20:55
