Date/Time: Mon, 29 Apr 2024 14:48:59 +0000
File Sharing - Global configuration
View Count: 1157
[2020-06-27 20:33:58] |
User612901 - Posts: 25 |
Hi Background: - a user shared one .cht with me for the first time - two files appeared in my Account control panel.... the first named "Sierra3.cfg.new" and the second "ES.cht" - not expecting two files, I opened ES.cht, and got a message asking if I wanted to apply new Global Configuration? Not wanting to override my settings I replied no. the ES.cht opened several charts which were blank. - I suspect ES.Cht is looking for settings in the Sierra3.cfg.new file Questions: - does ES.cht need Sierra3.cfg.new? - will accepting "Sierra3.cfg.new" override my local (personal) Global Settings? - can I apply my settings to ES.cht? Thanks in advance |
[2020-06-28 03:12:36] |
The reason the charts are blank is unrelated to the global configuration. You need to use this command to translate the symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-28 05:57:27] |
Thank you, Translate symbols to current service worked. Does this mean I should ignore the "Sierra3.cfg.new" file?.... for my education, what should a file of this type do? |
[2020-06-29 05:36:17] |
Sierra_Chart Engineering - Posts: 14137 |
Yes, Ignore that File. For what that file contains refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
