Date/Time: Fri, 03 May 2024 09:06:31 +0000
Cant stop dinging sound
View Count: 1030
[2020-06-25 17:08:01] |
pse52 - Posts: 18 |
I’ve got this constant dinging sound in Sierra charts and I can’t figure out where it’s coming from. It’s not coming from any of my alerts as they are muted globally. I’ve also monitored the alert manager and disabled or set alert for "no alert sound." And gone into chart settings on all or almost all of the trade charts and found anywhere there were alerts enabled. I unchecked enabled and changed the alerts to no alert sound. The sound that I’m getting is the default windows dinging sound...not the default alert sound I've set for SC. Any thoughts? |
[2020-06-25 21:44:05] |
Refer to the documentation here for this: Alerts Manager: Disabling Alert Sounds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-26 13:13:32] |
pse52 - Posts: 18 |
I had already read this portion of the documentation and checked/done everything recommended. As stated in my original post I also muted all alert sounds. The sound i'm getting is the default windows beeping sound...not the sound my default alert sound. Thank you for your reply. Paul |
