Date/Time: Fri, 03 May 2024 00:03:30 +0000
File error
View Count: 484
[2020-06-25 09:48:09] |
User350416 - Posts: 43 |
Hi, Today i'm having many errors in the message log and had to restart SC several times. One of the recurring ones is File error when writing Charts to Chartbook file: C:\SierraChart\Data\6A.Cht Error: Buffer append error. | 2020-06-25 11:44:59.783 * Am also finding that the market volume profile and tpo sometimes load all the data for the chart and sometimes just a few days. It doesn seem to show a consistent pattern. Can you please help Thanks |
[2020-06-25 10:19:18] |
It sounds like Sierra Chart is running out of memory on your system. Refer to: Working With Charts: Out of Memory Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
