Date/Time: Sat, 11 May 2024 19:10:35 +0000
Saving Study Settings
View Count: 986
[2020-06-23 23:52:36] |
avs1000 - Posts: 1 |
Hello: I am trying to save customization to study settings. I'm referring to https://www.sierrachart.com/index.php?page=doc/ChartStudies.html#CustomDefaultStudySettings. However, I cannot find "Save These Settings As the Default" in "Settings and Input" tab. Version of SierraChart I'm using is 2120. Also, I'm tried "Save Defaults" option on in STUDY SETTINGS window. No matter which way I modify, SCStudiesDefSettings.ini is not getting written to and study customization are not sticking. in other words, after modifying study settings and "Save Default" (since I cannot find "save these settings as a default" option), removing the study and adding a study, changes (customizations) made are not persisting. Please advise. Amit |
[2020-06-24 19:28:04] |
There was a change to how the default settings are changed, and you are using the correct method by selecting the button for "Save Defaults". Also, the files where these are stored are in the folder named "DefaultStudySettings" which is located under the main Sierra Chart installation folder. But you should not be having any problem with this. Still, the first thing to do is to update to the current release (2125) and try on that version and see if you still have any problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
