Date/Time: Fri, 03 May 2024 23:44:54 +0000
Chart Region 2 in Trade DOM (see screenshot)
View Count: 1030
[2020-06-19 05:23:45] |
@TRADE_YOUR_PLAN - Posts: 126 |
I've looked around quite a but cannot find a way to reduce chart regions in a Trade DOM. I want to make the chart region area in the screenshot smaller. Is it possible?
Attachment Deleted. Trade DOM Region 2.png / V - Attached On 2020-06-19 05:22:48 UTC - Size: 73.97 KB - 344 views |
[2020-06-19 20:01:28] |
Refer to the information here: Working With Charts: Chart Window and Regions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-19 20:09:19] |
That does not address the Trading DOM chart region. I've hovered over the top of the region and it DOES highlight, but it will not move. Edit: I've also attempted to adjust the region using: Tools > Adjust Regions -- without success. Edit 2: Here's an 8 second clip showing that moving chart region dividing line doesn't affect the Trading DOM region 2 at all :) https://gyazo.com/8a9d972ad4764cbdb3eb4824745eb278 Date Time Of Last Edit: 2020-06-19 20:27:44
[2020-06-20 08:06:04] |
The Trading DOM is not really meant to have Chart Regions. This is why you cannot adjust them.
[2020-06-20 22:53:28] |
It is quite amazing to have close proximity studies overlayed/underneath a DOM; visual game changer. I suggest adding that function especially as I add studies to region 3, 4, etc. Would be useful to adjust them like charts. Thank you
[2021-10-13 02:54:55] |
indigominds - Posts: 6 |
+1
