Date/Time: Wed, 04 Nov 2026 15:40:04 +0000
AMP user & change from rithmic
View Count: 3348
| [2020-06-16 16:46:34] |
| User845062 - Posts: 9 |
Hi, currently I'm using the following - monthly payed through AMP: Sierra Chart Package 5 - 25$ CME Exchange data Bundle with market depth - 30$ Eurex with Market Depth - 20€ Rithmic data feed 20$ + 0.25$ per contract As you stopped supporting Rithmic it is not so funny anymore and since June I also do not get historical data anymore ... so you more or less force people to change to your services. If I understand it right, for whatever reason I do have to pay for two data feeds (Denali and TT) if I use CME and Eurex instead of only one Rithmic as now. Means: Sierra Chart Package 5 - 25$ CME Exchange data Bundle with market depth 30 or 31,20$ Eurex with Market Depth 21$ Denali Exchange Data Feed 20$ Sierra Chart Exchange Data Feed 25$ (or maybe reduced 15$) + 0.10$ per contract Means min. 15-25$ more per month. Am I right so far? What can be paied through AMP and what do I have to pay here? Do I have to start changing setup at AMP? By the way: Paying everything throug AMP is very compfortable, especially because I'm from Europe and so I don't need to setup another account and have to fund it. So it would be very nice if everything could still be payed through AMP. Thanks in advance. |
| [2020-06-16 19:56:56] |
As you stopped supporting Rithmic it is not so funny anymore and since June I also do not get historical data anymore . We should have brought full termination to Rithmic long ago. And you are right there are historical data problems when using Rithmic. What we recommend is that for users who require EUREX that you use CQG for now: CQG Trading Platform Service And then later when we offer on our Denali data feed EUREX, then you will have an exceptionally high quality EUREX feed with no market depth limits. Then you can switch to the Denali data feed and our Sierra Chart order routing service at that time. Alternatively: If you want to use the Sierra Chart order routing service, here is the breakdown of charges. All items are in USD and are per month: Cost of Sierra Chart. Denali Exchange Data Feed: - Denali Exchange Data Feed for Sierra Chart Order Routing: $20.00 - CME Group with Market Depth: $31.20 --Sub-Total: $51.20 Sierra Chart Exchange Data Feed: - Sierra Chart Exchange Data Feed for 20 symbols: $25.00 - EUREX with Market Depth: $21.00 --Sub-Total: $46.00 Order Routing Fees: $0.10 per side Monthly credit to your Sierra Chart account when using both Denali Exchange Data Feed and Sierra Chart Exchange Data Feed: -$12.00 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-16 19:59:05
| [2020-06-17 13:06:58] |
Thank's for your detailed reply. Truly said the described alternative "Sierra Chart order routing service" is a bit too complicated and expensive. So it's great, that you will add EUREX to your Denali feed. For sure I will go with your recommendation and I'm looking forward to your offer with Eurex in Denali feed. Keep up your good work! |
| [2020-06-19 02:15:28] |
Yes the upcoming EUREX data is going to be really great. It will be full market depth. Beyond 20 levels of depth.
| [2021-01-17 09:29:02] |
| User230940 - Posts: 121 |
Hello SierraChart, Is this recommendation still valide? What we recommend is that for users who require EUREX that you use CQG for now: CQG Trading Platform Service If yes, when is the integration of Eurex Data completed? Will than the additional fee of $25 for Sierra Chart Exchange Data Feed or $46 complete for Eurex unnecessary? thanks regards |
| [2021-01-18 04:27:32] |
No we are not recommending CQG for EUREX trading if you are with AMP. You should use the Sierra Chart Order Routing service: Sierra Chart / Trading Technologies Futures Order Routing Service The new EUREX data feed should be out before the end of January 2021. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-18 06:31:32] |
Hi, thanks. That`s sound good. Will it be possible to order Eurex via AMP directly? Will the additional price of $25 for the additional Data fee become unnecessary and only the Eurex fee $21 have to be paid? Thanks regards |
| [2021-01-18 09:42:27] |
Will it be possible to order Eurex via AMP directly? Not initially.The cost will be 20 USD per month for the Denali Exchange Data Feed and 25 USD per month for the EUREX exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-18 11:02:32] |
That means from the pricing point of view nothing will change. Eurex wills costs me $45 vs $20 with CQG. I have to pay it directly to SierraCharts. correct? regards |
| [2021-01-19 05:00:44] |
Yes you are correct about the pricing. Thinking about it some more, the EUREX data feed can be paid through your AMP account. That will be supported initially. And also the EUREX data feed we will provide is far beyond the capabilities of anything CQG offers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-19 05:01:13
| [2021-01-19 06:21:16] |
Do you have a List of capabilities which are far away and much better than CQG? The pricing is much, much higher too CQG: CME Bundle $31 Eurex $20 Complete $51 SC TT-W Denali Exchange Data Feed for Sierra Chart Order Routing $20 CME Bundle $35 Sierra Chart Exchange Data Feed $25 Eurex $21 $105 - $12 (if both are in use) $89 $89 vs $51 |
| [2021-01-19 15:58:31] |
Yes refer to: New Upcoming EUREX Full Order Book Data Feed (Now Available!) Your pricing is definitely not correct. It is: CME bundle: 31USD EUREX EOBI: 25USD(Estimated) Denali Exchange Data Feed for Sierra Chart Order Routing $20 This is all. And we are working on new service packages which include the Denali data which will overall give you a better value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-19 17:22:58] |
Today my calculation is correct. Today I have to the order via AMP Denali Exchange Data Feed for Sierra Chart Order Routing $20 CME Bundle $31 and via SC Sierra Chart Exchange Data Feed $25 Eurex $21 The SierraChange Exchange Data Feed will become unnecessary for Eurex? When it will become possible to order? thanks regards |
| [2021-01-20 04:30:25] |
The SierraChange Exchange Data Feed will become unnecessary for Eurex? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
