Date/Time: Sat, 18 May 2024 18:26:16 +0000
v2120 - Can't open Associated Watch List for one specific chart. Fine for others
View Count: 508
[2020-06-15 15:38:58] |
jaxscott - Posts: 57 |
Can't open from a command bar drop down watch list OR from chart -> Associated Watch List menu item. Fine for other charts, just this one particular chart? How to fix? Thx |
[2020-06-15 16:03:14] |
See if this is the problem: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display (30.40 - Dialog Windows Do Not Display) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-15 16:03:37
[2020-06-15 16:46:45] |
I’ll try these but why would this be a problem with just one chart of several in the same Chartbook?. Opening their AWLs pose no problem under the exact same conditions.
Date Time Of Last Edit: 2020-06-15 16:47:13
[2020-06-15 18:19:58] |
We do not know. This is going to be a Windows operating system issue. These garbage and we mean absolute garbage Windows operating system dialogs are going to be removed in Sierra Chart before the end of this year. There is extensive development we are doing to replace them all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-15 18:20:34
