Date/Time: Sun, 19 May 2024 18:16:37 +0000
Issue with new update?
View Count: 477
[2020-06-11 12:57:46] |
User389151 - Posts: 37 |
Hi I updated sierra chart from 2005 to 2115. My charts are not loading. See attached. Please help. Thanks
SierraChart.JPG / V - Attached On 2020-06-11 12:57:06 UTC - Size: 219.53 KB - 225 views |
[2020-06-11 13:47:57] |
John - SC Support - Posts: 31733 |
If this is still a persisting issue, then we need to see your Message Log. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
