Date/Time: Sun, 19 May 2024 15:32:39 +0000
Bracket target and stop orders not working
View Count: 936
[2020-06-10 15:47:23] |
User112628 - Posts: 2 |
Hello, My bracket orders are no longer showing up in the chart or the DOM. Can you please assist? |
[2020-06-10 18:18:35] |
Do you see these particular orders listed in the Trade >> Trade Orders Window: Trading Information Windows: Trade Orders Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-10 18:18:45
[2020-06-10 19:08:02] |
I got it working. Only the parent order would show in the orders window. I have a primary customized trading window/dom that is linked to a chart. I had to open a separate trading window on that chart and adjust the adjust the brackets there to get them to show up. I'm also having to continue to use that separate window to adjust the target settings. The only thing I've done since yesterday when it was working is replay the chart. Does my customized trading window/dom "unlink" itself after replaying? Is there anything I can do to prevent this from happening?
[2020-06-11 04:55:25] |
This is not completely clear from our perspective. Refer to the documentation here: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM And also disable any Trade Window linking you are using: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
