Date/Time: Sat, 18 May 2024 12:03:14 +0000
Trading DOM Questions
View Count: 1417
[2020-06-06 20:00:01] |
User900334 - Posts: 3 |
Dear support, I have two questions with respect to the trading DOM: 1) When I change the tick size in my chart settings, the Trading DOM Asks/Bids showed still are displayed at the 0.5 tick size level. I want my asks and bids aggregated per the tick size level I choose in my chart settings so I have a better overview. 2) I only see asks/bids which are near the current price. I want to see all the asks/bids in the orderbook. Changing the market level depth in chart setting to 100 doesn't work. 3) Is it possible whenever a bid/ask gets changed in the order book, its highlighted in a colour in the ladder dom? I'd like to know whenever a bid/ask order is significantly changed. I uploaded a picture highlighted with blue the items I described above. Thank you so much! Kind regards, Date Time Of Last Edit: 2020-06-06 21:19:12
Sierra chart pic.JPG / V - Attached On 2020-06-06 19:58:48 UTC - Size: 47.16 KB - 330 views |
[2020-06-07 14:06:56] |
seandunaway - Posts: 214 |
I set Market Depth Combine Increment in Ticks to 1; then as I adjust the tick size, the depth fits appropriately. https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=default#MarketDepthCombineIncrementInTicks |
[2020-06-08 03:03:38] |
Refer to: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) And: File Menu: Not Receiving the Full Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 12:35:41] |
Dear support, Thank you for your reply. When changing the market depth combine increment in ticks in advanced settings 3 I have two problems: 1) If I change the number to 1, it does not change anything. If I change the number to 2, it does change as expected. I have provided 2 pics, one pic with parameter 1, and one pic with parameter 2. 2) The other columns are not changing even if I set the above parameter to 2, see the right columns in both pictures. Thank again! |
Sierra chart 1 market depth.JPG / V - Attached On 2020-06-08 12:35:26 UTC - Size: 156.83 KB - 347 views Sierra chart 2 market depth.JPG / V - Attached On 2020-06-08 12:35:33 UTC - Size: 131.04 KB - 287 views |
[2020-06-08 19:26:59] |
Update Sierra Chart to the current version: Software Download: Fast Update 2. There is not support for combining those other columns. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
