Date/Time: Tue, 14 May 2024 09:58:21 +0000
my data from Denalli does not match anyone elses data using the same charts as I am
View Count: 477
[2020-06-05 18:52:52] |
User420219 - Posts: 4 |
I use sierra chart, and subscribe to Denali for data and CQG for execution, however none of my data for delta or zigzag waves seems to be comming from Denali, instead it seems to be CQG data, how do I resolve the issue so I am seeing the denali data but executing on CQG? I do have an [M] in brackets in the upper right hand side of the chart. Thanks. Date Time Of Last Edit: 2020-06-05 18:55:56
[2020-06-05 22:05:19] |
[M] confirms that the data is coming from the Denali data feed. 1. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration 2. Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
