Date/Time: Wed, 15 May 2024 07:46:55 +0000
connection data
View Count: 454
[2020-06-05 15:52:11] |
Guilhem Maignan - Posts: 3 |
Hello, I have an issue with connection data. message error : an established connection was abandoned by software on your computer which software ? How to solve the problem ? Best Regards |
[2020-06-05 18:03:02] |
We see you are using Rithmic. Refer to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Can you tell us who your futures broker is? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
