Date/Time: Wed, 15 May 2024 07:18:38 +0000
changing drives
View Count: 493
[2020-06-04 18:25:47] |
markuz - Posts: 90 |
from client: "I had to change to the D Drive as my C Drive was full. After reinstalling, I am having a beeping sound. How do I check the location of this sound? Alert Window - all alerts Is there a new high/low alert somewhere? I am getting beeping without alert window changes. Thanks" |
[2020-06-04 23:46:03] |
You need to check the Alert Manager: Alerts Manager And also refer to: Alerts Manager: Disabling Alert Sounds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 23:46:37
