Date/Time: Fri, 10 May 2024 17:44:56 +0000
is there a minimum chart width requirement?
View Count: 464
[2020-06-02 14:04:05] |
MMX - Posts: 119 |
I have 3 charts in my 18 chart chartbook that are not holding their saved position once the chartbook is closed. These 3 charts are all one minute charts, they are all very narrow and scrunched up, and once the width is set, they remain perfectly positioned throughout the trading day, as long as the chartbook is not closed. Once the chart book is closed, then reopened again, these 3 charts have expanded their width by 50% and have to manually be reset again to the proper chart width that I want. What can I do to get these 3 charts to hold their saved position, and remain in that position every time the chartbook is opened and closed?
[2020-06-04 06:04:55] |
This is not exactly related, but refer to: Window Size and Position Not Restored When Opening Chartbook But the answer there is essentially applicable. So we cannot do anything about it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
