Date/Time: Sun, 19 May 2024 00:53:15 +0000
No connection
View Count: 457
[2020-06-01 10:21:00] |
User446139 - Posts: 7 |
Hi,i can not connect to SierraChart,is there a problem?
[2020-06-01 15:27:59] |
You are using Rithmic. Refer to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
