Date/Time: Wed, 15 May 2024 17:25:46 +0000
Trend Channels moving on tick charts...
View Count: 1148
[2020-05-29 21:34:18] |
User414533 - Posts: 93 |
I have researched some of the posted info on lines moving on tick charts and I am confused. I have not had this happen on other platforms. I even lock the trend channels and they still will go screwy after a few price bars. This is quite frustrating. Any new guidance on this? Seems like a serious bug that shouldn't be happening on a platform of this caliber. Two points connected should always be two points connected regardless of what happens beyond the "hard right edge"... Thanks. |
[2020-06-05 01:49:10] |
Any tips on this phenomenon besides continually cutting lines so they stop before they enter the fill space? :(
[2020-06-05 04:16:36] |
Ackin - Posts: 1865 |
Do you have a picture specifying what you are writing about?
[2020-06-05 05:14:49] |
Hmmm... I will try to take a before and after photo next time it happens. Basically I set up a channel and extend the lines so it functions like a ray. As price progresses, the channel lines will move (usually wider) than what I set up. It gets confusing because as the trading day progresses and I revisit my older channels, I notice several are usually a bit screwy (lines that used to be at candle closes are now further above/below the original placement. I read on the Sierra documentation that this has something to do with calculating the angle beyond the locked fill space. It doesn't make sense to me. Why can't a locked channel stay along the line it was originally placed... new candles be damned? :/ |
[2020-06-05 10:11:26] |
The documentation here explains this: Lines/Rays or Other Chart Drawings Move After Drawing Them: Right Side Fill Space and Variable Chart Bar Timeframes No need for this: Hmmm... I will try to take a before and after photo next time it happens.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-05 10:12:28
[2020-06-05 19:29:55] |
Okay, thank you! I believe that answers my question. Just to be certain: When setting a line, do not extend it past the last visible candle. After the line is established, I can then "extend drawing" with no fear that my angle will be changed in the future?
20200605_135605.jpg / V - Attached On 2020-06-05 19:27:50 UTC - Size: 105.84 KB - 251 views 20200605_141043.jpg / V - Attached On 2020-06-05 19:27:59 UTC - Size: 130.22 KB - 239 views |
