Date/Time: Mon, 20 May 2024 18:24:21 +0000
Rithmic
View Count: 542
[2020-05-29 12:21:37] |
User941978 - Posts: 8 |
Hello I want to connect rithmic, but I keep getting the error message: To install select help - Download current version - on the installer enable install optional components. I install and activate everything but the error message keeps coming back. I cannot find the Rim folder under sierra Chart and therefore cannot insert the files Thanks |
[2020-05-29 12:28:59] |
See: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward You need to create the \Rim subfolder if it does not already exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-29 12:30:17
