Date/Time: Wed, 18 Nov 2026 09:19:13 +0000
Ampfutures
View Count: 1162
[2020-05-19 17:17:48]
maanag - Posts: 1
Good Morning,
I'm an AmpFutures client evaluating to switch from MC/CQG to SC. I want to trade on CME an EUREX
I guess I have to buy:
0$ for SC with package 3 (free for Amp Clients)
20€ EUREX data
37$ CME bundle data
20$+0.1$ per ct for TT ROUTING
Am I correct?
Is there a fee for EUREX datafeeding (via SC and not TT if I correctly understand)?
Thank you
[2020-05-20 00:37:43]
SC Support - Posts: 2114
Hi there Maanag,
Sierra Chart Exchange Data Feed (20 symbols): $25
EUREX Non-Professional Exchange Fee with Market Depth Data: $21
Denali Exchange Data Feed for TTFIX Order Routing: $20
See here for the CME Group Exchange Fee that you need:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
Documentation for Denali: Denali Exchange Data Feed
Note if you have a (1) Denali Exchange Data Exchange Fee + a (2) Sierra Chart Exchange Data Exchange Fee in the same month, you will get a $10 rebate
Hope that is helpful
[2020-06-01 08:13:50]
User267701 - Posts: 66
As a AMP direct customer I am a bit confused:
Your webside says: only Package 5 works with CQG = additional $25/month
But AMP platform setup page gives me the option to select "SC-CQG" and "Package 3" = FREE (not including exchange fees ofc)
Because me personally cant get consistent value out or market depth, i dont use it anymore. I rather try to keep it simple.
So what info is right/wrong?
I would like to be able to have SC Package 3 with top of book only.
Your Denali service doesnt offer Top of book. You wont continue technical support for Rithmic in the coming SC versions. So it looks like i have to choose CQG.
But if i have to choose only(is there another option i did miss?) between "Package 5 + CQG" and "Package 3 + Denali/TT" then ofc i go with the last because costwise its almost the same and
quality of data and technical implementation should be better.
Thx
[2020-06-01 09:52:28]
Why do you say this? This is not true. The Denali Exchange Data Feed supports the CME exchange fees without market depth data.
If you are just trading on the CME Group of exchanges, we recommend using the Sierra Chart order routing service. Connectivity is much more stable, and you will have server side bracket orders and the web-based trading panel.
Also the Sierra Chart order routing service gives you full long-term order fill history. Details:
Sierra Chart Order Routing Service
Date Time Of Last Edit: 2020-06-01 10:01:20
